Hello, Everyone.
How are they different ?
Thanks in advance for your time and help.
I think it's a quirk of the Mupad symbolic engine.
In Mathcad 11 the (Maple) symbolic engine produces the following quirky output:
It appears that e or the exp() function has a special meaning:
The first line gave the error "No symbolic result was found". which is understandable because e^x is always immediatley translated to exp(x). But the second line then surprises with the same error message; unexpected because exp(i)^i indeed IS in there. At least (third line) with any other variable we get expected results, giving clues for the way to deal with e as shown in the fourth line.
Hello! you could write it so:
It performs the exponential only if a = e. or to powers of e, for example a=3:
Thanks for your response, P.M. and Luc.
It seems my Mathcad 14 don't work (accept) with:
because :
furthermore :
and I wish learning,wish having your help in Mathcad 14.
Best Regards
Loi.
