Please help to solve the attached file.
y should be around 6.86 for the attached problem, but i am not getting the answer in mathcad.
There are some different errors you made:
Yyou have to use the boolean equal sign in the solve block if the calculation uses the variable(s) which is modiefied and searched for.
Without any iitialisation or definition T and A will be taken as the units Tesla and Ampere. If you initialize them with guess values you also have to solve for them, too
Find attached four ways to get the result:
So I guess 2) or 4) are the ways to go, but whatever method you use, V is not needed in the solve process and should therefore be calculated afterwards.
