Hi - see attached.
I'd like to show OOB with units of gram-millimeters (g.mm).
When I change the units from m.kg to g.mm it adds kg.s^2/m.
Can this be avoided?
Instead of g*mm try gm*mm
regards
Andy
Gram is defined in Mathcad as gm not g. G is the gravitational constant.
As gm is not an SI unit, I have redefined g as gm using the global definition.
I would recommend against doing that.
Mathcad recognises "g" as the value of gravity at the earth's surface (9.8 m/sec^2), which is why the you got "kg8s^2/m added to your answer at the start.
You can redefine g to be grams (g = gm) but it's better (IMHO) just to use the "gm" built in.
