Hello, I need help with settings Mathcad Prime 3.1. How I can improve visibility grid of the worksheet?
I can change the background color of the worksheet?
I don't think Prime 3.1 has the internal settings to do either.
You could try changing your screen contrast to see if that helps.
Thanks for the help.
Did it help?
There should be an option to set the background colour and change the grid colour.
Mike
I have improved the visualization of the grid with the contrast of my monitor.
