how to extract the all values of Sol Data of differential equations in Mathcad to Excel or CSV files
주봉_10843142
6-Contributor
I am using PTC Mathcad Prime 9.0 and really need to extract the all values of Sol Data of differential equations in Mathcad to Excel or CSV files.
I can only do make the graph with the data.
Your help or advice for the method will be very appreciated.
Hi
Data to Excel use WRITEEXCEL() function or the EXCEL component.
WRITEEXCEL() is found under Functions | Functions | File Access | WRITEEXCEL()
Excel Component is found under Input/Output | Data Import/Export | Excel Component.
WRITEEXCEL() can be used for large amounts of data while Component suits smaller datasets.
WRITECSV() does exactly what it says on the tin.
Cheers
Terry
Hi
Cheers
Terry
Make sure the data you want to export is in a vector or a matrix, it is not possible to export a range. ( There is a distinct difference between vectors & matrices versus ranges.) Without seeing your Worksheet, I suspect you are using a range.
Please attach your prime worksheet, so we can help you better.
You are talking about the solution of an ODE?
If you would have used one of the stand-alone solvers your result would have been a matrix and you should have no problems to export it via WRITEXLS or WRITECSV.
In case you used a solve block with odesolve( ), the result is a function and to export data you have to sample the function and create vectors for the x- and y-values.
You sure should provide your worksheet.
