any one know how to plot root locus ?I search it in Google,but cannot find an answer.
I attach to the message the following example "Root-Locus Technique" (example taken from the e-book for Mathcad: "Topics in Electrical Engineering"). Also, the following references will be useful for the study:
http://www.facstaff.bucknell.edu/mastascu/econtrolhtml/RootLocus/RLocus1A.html
http://www.biblioteca.org.ar/libros/90105.pdf
http://design.uwaterloo.ca/tutorials/mathcad/me360/Tutorial.pdf
Hello!
Which version of Mathcad are you using? I want to attach some of Mathcad example.
hello
i am using the Mathcad 14
thankyou very much!
Thanks for the links, its realy memory refreshing.
You're welcome.
