invalid index
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
invalid index
How to solve this , the result should have the same values in z and qcza...
Why Qcpt has different quantities it should have more than (6X1) l...ike the one in z and qcza
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
If you make the changes I had shown and replace the wrong q.... you should get a result and your expression for Q.CPT should be a vector with 5 (not 6 because your range i.n runs only from 1 to 5) large vectors.
Did you notice the remarks i made at the end of my last answer?
Any value between 12 MPa and 15 MPa would be set to zero. If thats not your intention but you rater want that value to be unchanged, you cold add the green highlighted statement.
The result vectors still will have one element less than the input and its first element will always be zero because q[1 never gets assigned a value.
Maybe its an option for you not to use the range i.n at all and use vectorization. That way all six vectors in q...anchors are used and not only the first five.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Your program uses a loop running from O+1 to last(z).
ORIGIN is set to 1 and z is a vector with just six(!!) elements (each of them is a larger vector).
So the loop is just run 5 times and the result is a vector with just six elements, the first one is never defined and defaults to zero.
Here an example:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
if you may have noticed that z is a matrics contains 6 matrics
I want to write a program for each matrics is z
Like the first row in z is a matric (1339X1) I want the function to be applied in all of them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Which function?
I don't see any function which could be applied to a 1338 element vector.
You could make the yellow highlighted change but then the function would fail because of the usage of the green highlighted q.cza which only has 35 elements.
You may also reconsider the logic of your program. If both if-conditions fail, q.i is not assigned a value (and would default to zero). Is this really what you had in mind?
Furthermore, the result vector will now have one element less than the input vector and its first element will always be zero because it never gets a value assigned.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
hmm I mistakenly wrote qcza it should be qcza;anchors in all of them . ( thanks for pointing that out)
I wrote funtion because I will be using the same operator in the following calculation.
What I need is to implement this program to all the data I inserted in (qcza;anchors) and z
not only for six times which is the number of rows in z but in all the rows values
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
it works . thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Sure, but I also hope that it calculates correctly - that the results are what they should be.
I am still concerned about the first value always being zero and the last one missing - but then maybe this does not matter at all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Why I'm getting zeros;(
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Because your function contains a loop that is executed for only ONE value of n, namely the index of the last element of this P..... vector.
Due to your picture (you should attach the worksheet!) I cannot see what the expression under the vectorisation is, but if it multiplies o with that element of array P... and with the variable thickness, then the result could very well be an array of elements all 0 (zero), because I suspect that o may be defined as 0.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
You sure meant a loop like
For the rest, as Luc already said, we would need to see the current version of the sheet.
o is defined as 1.49 m in the originally posted sheet.
"thickness" is not defined there. I guess this is a single scalar and vectorization in the program would not be necessary.
I guess that your function F(..) could be written in a very simple way:
Note that the formal parameter of a function can have any name (I have chosen P for simplicity) - it must NOT be the very same name of the actual parameter used when you later call the function.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I wrote thickness
you will find it in last page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
OK, so thickness is a nested vector as well. In this case your function F must have TWO arguments as otherwise there is no way to tell Prime which of the six vectors in "thickness" it should use.
One way to do so is (no vectorization in the program is needed as yu are just multiplying scalars):
But your function F still can be written simpler - this time vectorization is needed!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I see
Thank you so much
