對不起,先生
我的Windows已更新為10,但我的mathcad 15已損壞。
你能告訴我如何修好我的Mathcad嗎?
It still runs...
What is damaged?
Is it just the background colour?
You can fix that within Mathcad, through the menu: Format-> Colour -> Background.
Dear Luc
Even if the color is specified, the background color cannot be changed.
Please help me...
Try to uncheck Menü -> "View" - "Regions" and see if it helps.
What is your windows-setting for the background colour, and does it help to change that?
Dear Luc
Thank you for helping us.
I have a screen recording, maybe it will let you know what the problem is with my mathcad.
Whats your default printer and which page size is selected from within Mathcad?
Dear Werner
I found another problem, but I really don't know if it will affect Mathcad.
Ku is my customer, ECS is our company.
The yellow part is the problem I found.
I am not sure if its a problem that your customers license file says "call number is 0". It may be due to different ways a license can be created. Thats something PTC support should be able to answer - keep in mind that this forum is no official PTC support but "just" a user driven platform enabling PTC users to exchange ideas.
The two licenses clearly are for two different PTC Host IDs (= MAC address of the network interface card). This could mean that they were requested for two different computers or for two different NICs in the same machine. The latter usually is no problem for Mathcad 15 (Prime is more sensible in this respect).
Anyway I don't think that the license files have anything to do with the problem of the gray background you experience.
I had remembered a similar problem /gray background) in a thread long time ago here in the forum and at those times the reason was that Mathcad was set to kind of an exotic printer with a ridiculously tine page size. What looked gray on first sight were the page separator lines. Thats the reason I asked about the printer selected in Mathcad but I am in no way sure that you experience the same problem.
Dear Werner
Thank you for your detailed and clear explanation. it was very helpful.😊😊😊
Try to send your issue by using "Mathcad Support Center": https://support.ptc.com/support/mathcad_supportCenterEnterprise.htm
Dear Vladimir
Thank you for giving the website.
The case is working. 😊😊😊
