matrix I would like to have differences betweene two lenghts.
AZ_7383307
2-Explorer
Hi
I would like to subtract the values in the column by subtracting 2 from 1, 3 from 2, etc. and have results in a new column. Basacly i would like to have differences betweene two lenghts.
@AZ_7383307 wrote:
Hi
Here's a functional version that should work in Mathcad Express
Using ORIGIN = 0 makes life easier:
But if you have a different ORIGIN, ...
A programmed version would be more compact (and easier to read!), but I don't have a full Mathcad Prime at the moment.
Stuart
Mathcad Prime 8 version attached.
(To:AZ_7383307)
Here are my 2 cents
Its more versatile to use a utility function, especially when you intend to treat more than vector that way
Wow,... Thanks guys for your guidance,
