Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I'm using Mathcad 14 on XP Pro. I can watch MathCad through task manager from launch-to-crash and the longer it runs the more memory it uses. This continues until all available memory is used up and then you get the error that says "not enough memory for this operation." When I launch the speradsheet I'm working on currently, Mathcad is using about 50Meg. Everytime I recalc the memory useage grows. After about 10 recalcs I'm up to 1.7Gig and by then usually I get the error message. Is it possible Mathcad is hanging on to all the numerical output of each calc for undos? I've lower undos to 20 and no difference. Thanks for any guidance here.
The Mathcad version is 14.0.0.163 [build 701291152] I'm not using any of the symbolic functions. My spreadsheet is using the Runge-Kutta ODE solver rkfixed to solve a system of 10 state equations. The spreadsheet works fine but accumulates about the same amount of additional memory useage with each calc. It's like it's holding on to all of the data from previous calculations. Thanks
If you are only using 14.0 the first thing to do is download and install the latest service release. If you have a single user license that's M020. If you have an Enterprise license it's M035, but you should install M030 because M035 has a really bad memory leak. Richard
OK so I installed M020 and it runs much faster (appreciate that) but is still showing the same memory behavior (i.e. memory usage grows with each calculation until all available memory is used up). Should I also install M011 or is that integrated into M020?
M020 supersedes M011. Without the worksheet I can't think of any other suggestion. Maybe it's a bug, although I don't recall hearing about it. Unfortunately the main Mathcad forum has been down for over a week, so I can't search it to check if this has been reported before. Richard
