hi,
I am doing a program to form a 'stiffnese matrix'. But it does not work and shows a ƒ(any1) → [Unitless]. Can anyone take a look at it for me? I am a beginner of Mathcad.
Thank you so much.
It appears that the program requires 6 inputs while you only provided 5.
I hope this helps.
Norm
I hope this helps.
Norm
that is ture.........thank you so much. but it still does not work in another way......I am still working on it.....
Still cannot make it work. it shows 'the calculation does not converge'. Could you please take a look at it for me.......
Try to use a first operator ORIGIN:=1
See please the attach
IT WORKS! FINALLY............THANK YOU SO MUCH....
