Hi everyone!
I'm trying to solve a simple system with two ODE's and I'm stuck. I just do not see my fault.
Any help is appreciated.
Leander
Hi
wow, thanks for the fast answer!
So it's not possible to replace the case distinction with a variable?
Leander Rankwiler wrote:
Hi
You Welcome!
Try please.
Hi
wow, thanks for the fast answer!So it's not possible to replace the case distinction with a variable?
Sure it is and you did nothing wrong at all in setting up your equations.
There was only one small error in your first equation inside the solve block: There is a multiplication sign between F.s and the parameter parenthesis.
Werner
It is one way to the... Mathcad House >>>
One of your Fz(xh,xl) (in the first equation of the solve block) is not a function; it's Fs times (xh,xl)
Hello
many thanks! Perfect.
you saved my last nerve 😆
