The Lambert W function is not defined numerically in Prime. There exist (numerical) approximation functions for it, but I doubt if they will bring you closer to a solution for your DE.
Correct. That is because your DE contains the Lambert W function.
I doubt that you will find a symbolic solution to your DE though.
@LucMeekes wrote:I doubt that you will find a symbolic solution to your DE though.
I do not want to find a symbolic solution, but instead a numeric one
