parameter constraints with genfit?
ptc-2930462
7-Bedrock
Is it possible to include parameter constraints when using genfit? If so, how is it implemented?
I need to fit a non-linear equation (Richards function) and genfit crashes with the current setting. I supply all the derivative functions with respect to the parameters.
Any insight is greatly appreciated.
Ulrich Hopfer
Genfit only uses the derivatives with respect to the fitted parameters. I looked up the algorithm for the Levenberg-Marquardt method for non-linearized fitting.
6 REPLIES 6
I would suggest posting a worksheet.
I have added the worksheet to my question on constrains with genfit, as suggested by Mike.
Ulrich
You forgot to upload the data
Yet another thread which is more than one hour old and did show up for me 15 minutes ago. Looks like its getting worse.
It seems to be worse tonight. Maybe PTC are playing tricks on us :-).
