See if the attached file helps.
You must write the imaginary unit as 1j (without a space inbetween) and not just as j and you mixed up 1 and l (lowercase Letter L) quite sometimes.
thank you very very much
You mixed up variable i with imaginary unit.
I also corrected the wrong index in omega.1. You used a vector index but it should have been a literal index. This had no negative effect to the calculations, though, but it created omega as a 2 x 1 vector.
BTW, there is no need for PM if you have a follow up question.
thank you so much sir
dear @Werner_E
i'am afraid i need your help again , i tried my best to fix it on my own but i didn't succeed
this is the last part and i hope i wont bother you again
thank you in advance
You have to define the resistors R1, R2, R3 and capacity C1.
The error in your sheet is because those values are not defined, so you will have to define them by using := before you use them.
You defined S1 for index 0 to 30 but now you try to access vector values with indices 31 to 100 which do not exist.
So either use k:=0..100 in all places or k:=0..30 everywhere.
thank you so much i fix it
can you please tell why y looks different in the last graph ???
