please if someone can help it's so important !!!
9736186
8-Gravel
I tried to follow do the same but i get errors
@LucMeekes
(To:9736186)
See if the attached file helps.
You must write the imaginary unit as 1j (without a space inbetween) and not just as j and you mixed up 1 and l (lowercase Letter L) quite sometimes.
14 REPLIES 14
(To:9736186)
thank you very very much
please i need you help again with the graph this time .
@Werner_E
(To:9736186)
You mixed up variable i with imaginary unit.
I also corrected the wrong index in omega.1. You used a vector index but it should have been a literal index. This had no negative effect to the calculations, though, but it created omega as a 2 x 1 vector.
BTW, there is no need for PM if you have a follow up question.
thank you so much sir
dear  @Werner_E
i'am afraid i need your help again , i tried my best to fix it on my own but i didn't succeed
this is the last part and i hope i wont bother you again
thank you in advance
(To:9736186)
You have to define the resistors R1, R2, R3 and capacity C1.
yes but i don't think there value needed  @Werner_E
(To:9736186)
The error in your sheet is because those values are not defined, so you will have to define them by using := before you use them.
@Werner_E  i did it but still there is a 3 error need to fix
(To:9736186)
You defined S1 for index 0 to 30 but now you try to access vector values with indices 31 to 100 which do not exist.
So either use k:=0..100 in all places or k:=0..30 everywhere.
thank you so much i fix it
 can you please tell why y looks different in the last graph ???
@Werner_E
(To:9736186)
thank you very very much for all you time and help @Werner_E
