Can I shade the area between 2 functions? Is it as simple as int(f(x) - g(x)) or something more involved?
Also I would like to plot the intersect of 2 functions and label the point with coordinates - doable?
Many thanks in advance
Joe
Mathcad 15 or Prime?
15
Valery's solution is tricky (and limited) ![]()
You may be also interested in
All my life is a set of tricks (and limited). In Russia ![]()
1st gen russian immigrant - trust me, I know
In version 15, plotting both curves against the same independent variable and declaring them "error bars" as a plot format will "shade the area between them.
