Opposite to older MC versions PRIME has no possibility to compare files in two windows arranged vertically or side-by-side. Is this correct?
You can run two instances of Prime, one beside the other. Open the two files, one in each instance of Prime.
Terry
Hello Terryhandicott,
it works, however the handling in MC14 was more comfortable.
Guenther
