put mathcad worksheets in html
mjalali-2
hi
i want to put my worksheet in my site to use other users use this worksheets
how can i do it?
is it possible by mathcad calculation serve?
how can i download it?
link of download?
plese guide me
12 REPLIES 12
Hi Mehdi,
mehdi jalali wrote:
is it possible by mathcad calculation serve?...
This software is no longer available. But you can solve your problem using Mathcad Prime 3.1 SDK.
can you guide me more?
I have not mathcad prime,do mathcad prime read mathcad worksheets?
Mathcad Prime can convert Mathcad worksheets, but please be aware that Prime is missing key features from M15.
StuartBruff
(To:mjalali-2)
Yes and No.   The licence for Mathcad Prime includes a licence for Mathcad 15.  To convert files from Mathcad format to Prime format, you need to run a (supplied) converter program, which in turn needs Mathcad 15.   The conversion process is fairly effective, but there are still some significant differences between Prime and Mathcad, meaning not all of your Mathcad worksheets will run in Prime.
The best way to find out is to download the Mathcad Prime trial.  This gives you 30 days of full Prime capability, after which it drops down to a mode known as Prime Express that has more limited capabilities (eg, no programming) making it nearer the original Mathcad (pre version 8?).
http://www.ptc.com/product/mathcad/free-trial
Download PTC Mathcad 15.0 Free | PTC
Stuart
thanks alot Stuart
Yes, with built-in converter in Mathcad Prime can read the old file formats. Mathcad 15 must be installed and used in the process of conversion. At the same time on a single license file, you can work with both programs - Mathcad Prime and Mathcad 15. The latest service release for Prime - is Mathcad Prime 3.1 F000, and regular Mathcad - is Mathcad 15 M040. Also you can try download and use for free Mathcad Prime Express version (30 day it will be work in a full mode and then as "Express" version in a limited mode).
More about Mathcad Prime:
http://www.ptc.com/engineering-math-software/mathcad
Free Math Software Download | PTC
More about Mathcad Prime 3.1 SDK:
https://community.ptc.com/t5/PTC-Mathcad/NEW-API-for-Mathcad-Prime-3-1/td-p/12388
Video Link : 6067
thanks alot valadimir....
Is it possible to convert controls such as push button,list box,...in mathcad(that writen by vb script)?
mathcad prime has these Facilities?
thanks for guidance.
Scriptable objects are available in Mathcad 15, but not yet available in Prime.
Mike
StuartBruff
(To:mjalali-2)
As Mike say, they're not available in Prime.  The best way to find out what Prime 3.1 will do is to download the 30-day trial (which reverts to Prime Express after 30 days) and play with it.   In the meantime, you could look at the Migration Guide; Section 3 gives a list of the supported and unsupported features.   There's a link to the document here: Mathcad Prime 3.1 "Migration Guide" guide  (it's also included in the trial software).
Stuart
StuartBruff
(To:mjalali-2)
mehdi jalali wrote:
hi
how can i do it?
Roger's ears must have been burning ...
Customer feedback
Stuart
StuartBruff wrote:
mehdi jalali wrote:
hi
how can i do it?
Customer feedback
Stuart
No doubt. However, I cannot believe that this features is even are being discussed, before Prime has all the features that Mathcad 15 has!!!!
Mike
