"Find" doesn't work and I don't know why
361748
Dear people,
I've learned a lot from other people's faults from this forum in the past, but now I can't fix my problem on my own so I'm asking a question myself this time.
Its about the Find function, which has worked for me before, but not in this instance. Now I think it has something to do with the complexity of the equation I'm trying to solve but I'm not sure.
Maybe somebody can have a look at my file and tell me what I'm doing wrong.
Its about the A.var value which I cannot solve.
Cheers,
-MFra-
(To:361748)
Unfortunately it seems to me that the problem has no solution other than the trivial one. See chart: (x=A.var):
years ago, I published a similar work in the community, but I see that your work is more detailed. See Attachment.
361748
(To:-MFra-)
Wow thanks for the quick and helpfull response! Also for the attachment, didn't expect that. Its usefull.
Cheers,
LucMeekes
(To:361748)
Je verheft Phi.v(A.var) tot de macht w.2. Dat mag alleen als die Phi.v dimensieloos is.
Kennelijk is s/m^3 niet de juiste verevening.
Het helpt soms om de expressie even buiten de Given/Find te trekken en te evalueren om te zien of alles 'werkt'.
Succes!
(To:LucMeekes)
Hoi Luc,
Ja dat klopt. Het zat hem in de verevening (meters). Dankje voor de tip!
Groeten,
