Have made up some sample data. I think the unwrap program listed here is what you are after?
If in radians not degrees you will need to adjust.
It is Prime 7 so someone may save it back for you.
It does not take long to type in the unwrap function.
Cheers
Terry
Could you please supply the data as a starting point.
Cheers
Terry
Please upload your Mathcad Prime worksheet here.
Cheers
Terry
Prime 4 file enclosed you should be able to open this.
Terry,
Thank you for the solution....that is what I was looking for!
For reference, below is a method a coworker sent over, but your solution is more elegant since it does it in a single step.
Note: The matrix origin is 1.
In the future I will make sure to supply additional data.
V/R,
Quentin
I guess the easiest way would be to use the built-in function "phasecor".
Of course the argument vector has to be a vector of angles. Here is Terry's example using phasecor
thanks! That does work well.
Quentin
