"Variable not Defined" error when minimizing a function
IanCrehan
Hi
Im a new user to mathcad, I have created a mathcad sheet to find an the minimum value of a function by optimizing two parameters(Attached).I believe i have it set up alright but i am getting an error that a vaiable is not defined even though it is.
Can anyone help me to solve this.This problem has been annoying me for the last 2 days.
Thank You
RichardJ
(To:IanCrehan)
Here. I'm not sure you are going to like the answer though.
6 REPLIES 6
Ian Crehan wrote:
Hi
... by optimizing two parameters ...
Your Minimize statement contains nine parameters not two!
Also note (from Minimize help file): "If you are solving for n variables, the solve block must have n equations." Your solve block contains four equations.
Alan
I Taught that might be the problem and changed it (attached) But im still getting the same problem. For H two parameters (L0,ξ) need to be changed to optimize the solution while three parameters are user inputted constants (Z,Li,ψ) and the other four parameters are changed by the parameters (Fls,Fas,Mb,Vb).
I am trying another approach of defining the function H as a multiline function including all the previous functions which define H. Im not too sure how to do this but I will give it a go.
Ian
It doesn't look right at all.
If these are inputted by the user you don't need them to be a function of H.
It's still not clear exactly what your after. Are you trying to find H???
Mike
I am trying to find a minimum value for H by changing the Parameters L0 and ξ.These parameters are both directly applied to the equation for H and a number of other equations which are also applied to H.
Ian
RichardJ
(To:IanCrehan)
Thank You Richard,
That is working fine now. I completely misunderstood the Minimize function and layout. All I need to do now is add a few conditions to the minimize and debug the equations so that I get the right answer.
Thank You Again
Ian
