May I ask some help to improve my spreadsheet that will satisfy all conditions. Sometime the utilization of the bending moment is greater than 1 from my initial profile selections. I need to have a profile that are adequate in the design from the selections of the profile I attached . Here is the Mathcad file and read Exel file for your reference . Thank you..
If you want to loop through a worksheet until a certain condition is met you will have to turn the whole worksheet (the calculation of the bending force) into a function - manually.
Otherwise a worksheet is linear - top down and finished.
Its not clear to me what you want Mathcad to do when one of those values is greater than 1.
1st condition I selected a profiles from the deflection criteria of L/175,L/240+6.4 and L/240.
2nd condition I checked the capacity of the bending moment using the selected profile.
Sometimes the selected profile are not sufficient . I need another condition that will increase the profile to satisfy the 2nd condition
This works , thanks
