How would one set limits for the variable in the solve command. In the example below, I know that k has to be between certain values.
This Help page may be of assistance: https://support.ptc.com/help/mathcad/r8.0/en/index.html#page/PTC_Mathcad_Help/making_assumptions_about_variables.html
Thanks, I'll look into it.
Without further information it can only be recommended to use the "assume" modifier.
