shading an area under the normal curve
jsuarez
Is it possible to do with Mathcad of Mathcad Prime?
1: shade the area the encompasses the inner 68 % of the normal probability distribution, that is +/- 2 standard deviation from the mean.
2: shade the probability (0.212) that a random variable is below 360 with a mean of 400 and standard deviation of 50 pertaining to a normal distribution.
If yes, how?
Thank you very much!
Johny.
(To:jsuarez)
Maybe that way. The plottype of the second plot is "Column Trace".
It should be obvious how to change mean, std deviation and upper/lower limit at will.
RichardJ
(To:jsuarez)
