shortcut for vectorization
NO_10220522
3-Newcomer
Hey I'm having trouble with the shortcut for vectorization. It says to press ''Ctrl+Shift+^'', but how do i press ''^'', when I press the bottom whit ^¨~ on, it puts ''CONTINUE'' in... i I have tried to press ''Ctrl+Shift+alt+94'', and it does not work either. hope some have a solution to my problem.
(To:NO_10220522)
Are you using a "foreign" (= non US) keyboard?
On my German keyboard I have to press Ctrl-Shift+6 (not the 6 on the numeric keypad!) even though the tooltip wrongly says Ctrl+Shift-^
Shift-6 on German Keyboards give the ampersand (&) but on US keyboards Shift-6 gives you the caret (^).
Documentation/Help and tooltip should be adjusted accordingly.
Adaptations to other languages and keyboards was never done very well in Prime and there even are unfortunately some shortcuts that are not available on non-US keyboards at all.
(To:NO_10220522)
_0
(To:Werner_E)
Thanks for sharing such great information, I highly appreciate your hard-working skills as the post you published have some great information which is quite beneficial for me, I hope you will post more like that in the future
