the 'hat' symbol
rwpatterson357
the 'hat' symbol
How can i add a "hat" symbol above a variable?
thanks,
russ
5 REPLIES 5
Mostly you can't. In MC14 you can use the combining ^ character (Unicode). It works with some fonts, but not with all.
__________________
� � � � Tom Gutman
[Alt] 182, 210, 215, 256 ... �, �, �,
for some standard ASCII, look for more from CharMap.
jmG
>above a variable?
These are the ones I most often use. To enter, toggle NumLk, then hold down the Alt key and use the numeric keypad to enter the number.
Example of using the combining ^ character. You might be able to find a font you find acceptable that renders this correctly.
__________________
� � � � Tom Gutman
>above a variable?
>thanks,
>russ
We can (in WebSheets) and must (in WorkSheets - in future) use pictures as variable name.
See one Mathcad WebSheet without any limits in variable names:
http://twt.mpei.ac.ru/MCS/Worksheets/Non_St_Name.xmcd
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
