two questions? need help
ptc-4648607
1.First question? How i can change axis unit? i want degree? i was searching tip in google and only find answer "To set the units in a plot, divide the plotted parameter by the desired units" i don't know how i can do it?
2.Second. I need answer of my graph, i need a (alfa) value where the functions are collising?
1 use alpha/deg on the x axes
2 use Trace
7 REPLIES 7
2 use Trace
thanks
thanks
You welcome!
One Mathcad-video from LT:
http://communities.ptc.com/videos/2101
mindaugas3.PNGi have understood trace, but how it convert apha/deg i don't know, i write near alpha on axis "/deg" but it don't show degree. Can you help, also i would like that find command show not radian but degree.
See the file.
Read the Help.
thanks , i understand now, there was problem with degree range. Thanks
We can use this tools for the guess value setting:
http://twt.mpei.ac.ru/ochkov/T-2012/2_12_Zoom_Trace.png
And second.
For one equation (not for a system) better use not Gthe iven-Find but the root function!
