The mathcad is unable to solve definite integral to yield array output. The input is also in array form. Even if I put limits in the closed form of integral it yields only a single value instead of array. Please solve this problem. The integral and other steps with problems are highlighted.
Sorry, for the delayed response. That is the solution which was required.![]()
thank you
Can you please find sometime to answer my other questions? thank you
thank you
