vb script for mm to fractions of inch conversion
ptc-4497948
I need to convert mathcad 15 results having mm to fractions inches using scriptable objects)
collab+-+14+12+04+fractions+02.JPGDo you mean something like the attached?
Stuart
7 REPLIES 7
RichardJ
(To:ptc-4497948)
There is no easy way to do that. It would require a lot of programming, especially if you want fractions based on anything other than tenths (i.e. n/10, n/100, etc.).
Thanks for replay me Mr Jackson.
round of 3/16 fraction is required for me.
Why do you need to do it in vbscript? And what kind of result / output do you need?
Stuart
(To:ptc-4497948)
Like Stuart I am also wondering what you plan to do with the results of the script. In Mathcad it would be a string (which you can get using Mathcad alone, too) which would be just good for viewing. If thats the goal, you might as well use Mathcad on its own and better let the result be something you can reuse in Mathcad like the matrix I had chosen.
Thanks for your quick replay, what i want to convert to mm to inch fraction is clearly mentioned in the attached MathCAD sheet.
Please help me ASAP
Stuart
Thank u so much Mr Stuart ,How can i change this to fraction is multiple of 3/16 in.
