do you have an idea avoiding those problems 😉
The flipped text only occcurs in Mathcad, the copy and paste image is clean.
The misused 90° projected 3D plot prints the numbers on the axis. Why not using the 2D version? Because you have to mess around with indices, in teh 3D version you can simply add the Vector
Unfortunately there is little possibility to shape the text.
cheers
I don't think there is much you can do about the text quality, but you can improve the appearance of the x-y plot by turning off the axis numbering in the axis that's 'normal' to the plot (eg, if you are plotting the x and y axes, turn off numbering in the z axis).
Stuart
Dear Stuart,
thanks yes - the fonts may only be changed for the whole doc, and there is little to improve on that...
the flipped text goes away when copying & pasting
regards
Gerfried
