hi all,
i'm trying to insert an image into a prime 2 worksheet. i can copy/paste it or use the "insert image region" tool then browse to it. many different formats show up in the sheet properly (jpg, png, bmp, tif, gif) but when i try to save, i get an error.
how do i get na image into the sheet?
No problem with Mathcad Prime 3.1.
Do please upgrade!
how do you do it in prime 3? cut/past? or do you use insert image region then browse to file?
Both!
Both methods work fine in Prime 1.0 on my computer. Unless there is something specifically wrong with version 2.0, I don't think upgrading is necessary to resolve the issue (although, upgrading to version 15 might be wise).
Have you tried an uninstall/reinstall of Mathcad?
