Addressing when connect to a device using Open Protocol?
Tan_Tran
I am testing a device using the Open Protocol (Torque Ethernet Driver) to connect to KepwareEX for gathering data. I have read the driver help but not sure what to type in the address field. It said the address syntax is ITEMNAME<BIT.INDEX>. For example, if I want to read the data "Last tightening Results" with MID 0061, so the ITEMNAME should be LTR_TORQUE_VALUE, isn't it?
According to the Open Protocol user guide, if I want to use MID 61, revision 1, the torque value is from the byte 141 to byte 146. What should I type in the address tag field on Kepware OPC server?
Could you give me an example?
Many thanks,
Hi Tan_Tran,
You are correct the address you need is LTR_TORQUE_VALUE, if you want the current Torque value. Are you experiencing any issues using this address?
Rob
