Where can i find the Administration and Configuration module ?
I am trying to setup an asset for maintenance but i cannot find that module in my mfg apps menu.
Hi @rodolfocorral.
Click the hamburger menu in the upper left corner? If looks like this:
From there, you should see a series of tiles:
Note: these are the standard tiles available out of the box. You may have additional custom tiles.
If you're not seeing the Configuration and Setup tab, it could be a permissions issue. You can validate this by logging in with the Administrator account, then selecting Configuration and Setup from the hamburger menu (Users tab) for applying the needed permissions.
--Sharon
If my response has answered your question, please mark it as the Accepted Solution, for the benefit of others who may have the same question.
Thanks for the reply, i dont think it is a permission issue.
Looks like the window that i am looking for is not in that option anymore.
These are the steps that i am trying to follow:
But i think is for an older version of Mfg apps
Hi @rodolfocorral,
Are you using the Administrator user? Please share the screenshot of the tiles visible at your end.
Here is the link of latest documentation : https://www.ptc.com/en/support/refdoc/ThingWorx_Apps/8.3.0/ThingWorx_Apps_Setup_and_Configuration_Guide?&art_lang=en&posno=1&q=&DocumentType=Reference%20Document&Product=ThingWorx%20Manufacturing%20Apps%20Family&Release=8.3.1&source=search
Himanshu
I am using Administrator account, you will see the menu in the attached image.
What i am trying to do is to set a maintenance time for one of my devices, so any alert during that time can be ignored, but i just cant find how and when to setup this.
