1.Is it possible to download the properties data history as a 'report' in Asset advisor? Is there ay option to do that?
2.Also the default chart in Asset advisor is Time series chart. Can we use any other charts instead of time series
I haven't really done much with Asset Advisor, but it is based in Thingworx, so you can do all the things you want by extending Asset Advisor with your own services and mashups.
Hi @Sruthi.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
