Can I add KPI function from SCO Apps to SCP?
eyli
Thingworx SCO has the KPI function. Can this function be added to SCP?
PaiChung
22-Sapphire I
(To:eyli)
Manufacturing start apps comes as an extension
5 REPLIES 5
PaiChung
22-Sapphire I
(To:eyli)
With KPI function if you mean the OEE / Availability, Performance, Quality.
Those are calculations that can be fully customized but work with some set definitions OOTB and generally are mapped to tags/properties in the model. Also there is roll up that follows the ISA 95 model.
They are part of the Manufacturing Starter App.
Can you use that in SCP, certainly, not sure how you are looking to use it.
Also not sure in regards to the impact on  licensing.
eyli
(To:PaiChung)
Thanks for your reply. Do you know how can I import the KPI apps to SCP model?
PaiChung
22-Sapphire I
(To:eyli)
If you have enablement on your license for the SCO apps, they can be downloaded from support.ptc.com together with the installation instructions.
eyli
(To:PaiChung)
Thanks. I see. So may I know is it a standalone installation package or an extension to be imported to Thingworx platform?
PaiChung
22-Sapphire I
(To:eyli)
