I had installed manufacturing apps 8.4.3 extension on Thingworx plaftorm 8.4.5 with PostgresSQL 10.
The installation went ok (without errors) but I can't see the filters in the asset advisor window (attached is the screenshot). I am logged as Administrator.
Any idea of what is happening?
Thanks in advance.
Hi @olatz
CSS doesn't get rendered properly in ThingWorx 8.4.5. This causes the expand/collapse button to not display properly. Could you please try these steps:
1. Please navigate to PTC.FactoryConsole.DataTable
2. Go to Mashup tab of PTC.FactoryConsole.DataTable , look for the mashup in the "TitleMashup" for Asset Advisor i.e. PTC.SCA.SCO.AssetMonitor.AssetList.AssetListContainerMashup
3. Edit the Mashup
4. Go to the CSS tab and paste the following snippet there:
.customClass label:before {
display:none !important;
.customClass label {
background: url(/Thingworx/MediaEntities/PTC.Factory.CollapseTab) !important;
height: 17.988px !important;
width: 17px !important;
display:inline-block !important;
5. Apply customClass on the master tile mashup, that will apply it to all mashups that use it
Abhishek
Hi @olatz
3. Edit the Mashup
Abhishek
Thanks Abhishek. This solution solves the problem but not completely.
Now, I can see the image to click and expand the filters, but this image doesn't change. I mean, it should be in one position when the filter is not expanded, and in another when the filter is expanded.
Olatz.
Hi @olatz
Could you please attach a screenshot of the issue that you were facing now, that you have mentioned above. The screenshot will give a clear fixture of problem you having currently. You might just need to modify the css that i have provided you.
Abhishek
Attached two screenshots. There you can see that the icon doesn't change even if the menu is displayed or not.
Thanks.
Olatz
Hi @olatz
Thanks for supplying the screenshot. You can fix the modifying the custom class supplied by me. update the value og height and weight and try.
Abhishek
Hi @olatz.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
