Communication failure between Industrial Connectivity and Foundation
einsfele
Hi everyone,
My configuration:
ThingWorx Industrial Connectivity 8.4.66
ThingWorx Fundation 8.4 (30-day Evoluation Server)
I am using Industrial Connectivity to get data from PLC and bind it on my dashboard. I was able to do it.
But I have tried get data from other PLC (through of industrial connectivity too) and I could not do it work well.
The quality of connection is "unknown"
And I guess  the communication between PLC and Industrial Connectivity is work well.
I have ever verified if there is any firewall blocking me but it is ok.
has someone could help me it?
Below other configuration:
Regards
rsharp-2
(To:einsfele)
Thank you for the post. Are you able to see the data for this tag in the opc quick client? In the device properties in Logix options are you using Logical non blocking protocol or is it in Symbolic protocol.
slangley
(To:rsharp-2)
Hi @einsfele.
If the response from @rsharp-2 lead you to a solution, please mark it as the Accepted Solution for the benefit of others with the same issue.  If you found a different solution, please post it and mark that as the Accepted Solution.
Regards.
--Sharon
