Connection drop after device restart - IGS
Mihir_solanki
2-Explorer
I have a device connected over Modbus TCP/IP channel and logs data correctly. OPC quick client shows correct value. Once i turned off device, data quality is bad because of no communication. when i restart a device, there is no good data seen in OPC quick client. I have to delete channel and device and re-add it again along with tags. Once i will do it, it will start showing good quality data. Everytime i can not do that when i am using this during live production. Can you please suggest where i have to focus for this?
Sometimes it has been observed in log that it shows error code 10061. 'Socket Error Occured connecting'.  Error=10061. 'No connection could be made because the target machine actively refused it'.
1 REPLY 1
abjain
(To:Mihir_solanki)
@Mihir_solanki  : I see that you have already raised a Salesforce ticket for this issue for Kepware. Someone from kepware team would respond on that. Please follow up on that case henceforth for this issue
