Hi team,
I am trying to deploy the "DemoFactoryPackage" from https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard/Get-Started/Configuring-the-Apps-with-Demo-Data-Set-and-Si…
for simulating data of Assets and lines between KepServerEx 6 and Thingworx 8.0 MannufacturingApps.
But after doing the import of the File DemoFactoryDataSet.zip on the MannufacturingApps I don't find any of the Assets in the MannufacturingApp or Thingworx Composer.
Are the files on the link above wrong (I see a difference in the name, in the guide i see "DemoFactoryData-05-17-2017.zip" while in the current file is "DemoFactoryDataSet.zip")?
Thank you.
Greetings Oscar Morales,
The file is correct and the name is "DemoFactoryDataSet.zip" .
If you open this file there should be entities folder which will contain the assets.Here is the screen shot :
Has anyone else had the same problem?
Thanks.
