Error while using the mfg data import block
MK_10775467
I am trying to use the mfg data import block to import data in the DPM. I am facing errors while I am trying to import the excel file. It gives me error that some rows have failed to import. Can some tell what is the exact way to import the data in DPM.
Please provide a screenshot of this error.
This is the error I am getting while importing data. I am using the PTCSC.DataImport.MainFrame_MU mashup to import data. I have added the excel file which I am trying to import.
Before importing, validate your data against any rules or constraints set by the DPM system. Also Check if there are any limitations on file size or number of rows that can be imported at once.
