We are aware of an issue with eSupport impacting community login. We are working on a fix and community login should be restored soon.
I tried many times I don't know what is the problem , please I need help !!
Hi @AhmedSaafan ,
It seems there is an configuration issue at your Kepware side. Can you validate issue by setting connection settings values as below:
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
Himanshu
I did that it also failed , I don't know what is the problem ??
Hi @AhmedSaafan ,
Can you please double confirm the port number is 8443 for thingworx server (it might be 443). Also please check thingworx server is reachable from the server where KepServerEX is installed.
Himanshu
Thanks for replying
I don't know how to know that Thingworx server is reachable for kepserver
there is something called SSL error always occurring in event log
Hello Admed,
Can you try to do telnet with you <ip of your thingworx server><port> and try?
Manoj Pathak
Thanks for replying
Can you explain more how to use telnet to solve my problem
Hi @AhmedSaafan ,
Telnet is basically used to check the connectivity between two servers. Its upto you which approach you use to validate the connectivity between ThingWorx Server and Kepserver machine.
Himanshu
Thank you
