How to config Plan time and make multi shift ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I need to change plan time to "08:00 - 17:00".
But, It's error like below picture.
How to change it???
And I need to make multi shift plan time. How to do that?
- Labels:
Best Practices
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hey @ssriuaipornchai
the second field is the duration and not the end time of the shift. So in your case you have to enter 08:00 for start time and 09:00 for the duration (9 hours from 08:00 am to 05:00 pm).
Multi shift is not available out of the box but can be implemented by customizing the KPI calculation.
Seb
Principal Solution Experience Architect
PTC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Please, Show me about customized KPI calculation.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Sorry i have to correct my self after talking to our product management team.
You have to write your own service in Thingworx Composer that calculates the KPI´s based on your shift mode. The current version does not support adjustments in the existing calculations.
We are currently working on a flexible and configurable KPI calculation that also supports multi shift models. This is planed for the next major release in June.
Seb
PTC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
We need multi working shift.
And the working shift is cross the days.
Please, dev new version for support.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @ssriuaipornchai ,
With current implementation of manufacturing apps, we are limited when it comes to time management in general. We are planning to implement this feature in future releases.
Himanshu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Today is 27-09-2019.
When are you release multi shift ???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
The Thingworx 8.5 which was released last Friday has newer Shift capabilities. It will support multiple shift and calculation of KPI based on shift.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Ok. I install MFG 8.5 already.
I reading Help center in "Calculating KPIs Using Job Orders Rather Than Shifts" and following this instruction.
I am not understand about UID Job Orders.
What should I fill "UID" in "JobOrderUID" properties?
What is UID stand for ?
In your help center is not easy for understand.
Please, improve it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @ssriuaipornchai,
I wanted to follow up to see if the response from @SebB answered your question. If so, please mark the appropriate reply with Accepted Solution for the benefit of others in the Community.
Thanks!
Leigh
