I want to add the 'message' column into the alert grid to show the current value and limit value. But I can not find a way to custom the alert detail mash. It's not included in the configuration of thing 'PTC.Factory.C_LaunchPointConfigurationThing_8.3.0_05'.
Hi @zhuwenxi,
You need to create a custom alert monitoring mashup and need to replace with the pre-defined alert monitoring mashup.
You can replace the existing mashup in PTC.FactoryConsole.C_DataTable_[ReleaseVersion] for PTC.Factory.AlertMonitor
PFB screenshot for reference
You also need to set PTC.FactoryConsole.C_DataTable_[ReleaseVersion] in TilesDataTable of PTC.Factory.C_LaunchPointConfigurationThing_[ReleaseVersion]
Himanshu
Greetings @zhuwenxi,
Please check the mashup PTC.SCA.SCO.ConfigurationAndSetup.C_AlertsConfigurationMashup_[ReleaseVersion] and launch point key is AlertsConfigurationMashup.
Himanshu
Hi @zhuwenxi,
Himanshu
Hi @zhuwenxi,
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question. If questions are still pending, please post an update so we can continue to search for a solution.
Himanshu
