I have 3 type of cnc controller.
1. Fanuc Series Oi-MF
2. Mitsubishi M70
3. GSK 990MA ( China )
4. GSK 980TC3 ( China )
What driver name in kepware can get the data from upper controller list ?
With regard to your question about CNC integration with Kepware:
[SE]: You'll use our Fanuc FOCAS Ethernet driver
2. Mitsubishi M70
[SE]: Direct integration with the M70 is not possible. For Kepware, you'll need to front-end the M70 with a Q series Mitsubishi PLC. The Q series PLC will speak CC-LINK to the M70 controller and Kepware will speak MELSEC to the Q series.
[SE]: Unfortunately we have no documented history with GSK CNCs, and I'm not able to identify a common protocol shared between the CNC and Kepware. It would be a good idea to reach out to GSK to learn more about "external protocol interfaces" or ways to connect the CNC to a Windows PC.
Thanks!
Sam
2. Mitsubishi M70
Thanks!
Sam
Hi @ssriuaipornchai.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
