I'd like to modify the Production KPIs status history graph (attached file) from 1 week to 1 month.
Could you please provide me how to modify it.
Thanks in advance
Regards
Narirat
@Narirat : For this you need to customize PTC.Factory.C_ProductionHistoricalData_[ReleaseVersion] mashup. You can also refer to the customization guide for mfg apps for this
@abjain Thank you very much for your reply.I will try to do it.
Is this the customization guide for mfg apps https://www.ptc.com/support/-/media/99B4D4DE487C441096DF3FC5FE36C575.pdf?sc_lang=en ?
@Narirat That is for 8.3 mfg apps. For 8.4,here is the link: https://www.ptc.com/support/-/media/3B6F1E4328074DD9A0599DE9D3F1EDAD.pdf?sc_lang=en
@abjain Thank you for your support .
Sorry,Have no about the Customization Guide in here
This link ( https://www.ptc.com/support/-/media/3B6F1E4328074DD9A0599DE9D3F1EDAD.pdf?sc_lang=en) is ThingWorx Apps Setup and Configuration Guide.It isn't ThingWorx Apps Customization Guide.
Thank for advance
Narirat
@Narirat : Apologies. Here is the correct link : https://www.ptc.com/support/-/media/B4ECC4B78EBB4DAEAEF1C4D0308587BA.pdf?sc_lang=en
