Incorrect credentials
laue
I am using Thingworx 8.4 with Manufacturing Apps extension.
Unfortunatly, it is not possible to login (Adminstrator) to /Thingworx/FormLogin/Welcome or even /Thingworx/FormLogin. Instead I get the message: "Anmeldeinformationen stimmen nicht mit einer gültigen Benutzername-Passwort-Kombination für diese Organisation überein. Versuchen Sie es später noch einmal." (In English: Username and password for this Organisation do not match. Please, try again later.).
In the Security Log I get a Nullpointerexeption:
ApplicationContext.sessionDestroyed(HttpSessionEvent) failed. [ java.lang.NullPointerException: userName was null ][ userName was null ]
Eventhough the usernamefield is not empty.
What could be the Problem?
Cedrik
laue
(To:laue)
Problem solved. It was an issue with the port forwarding
3 REPLIES 3
hchanana
(To:laue)
Hi @laue ,
Can you double check your Administrator password.
Also can check if you are able to login to ThingWorx Composer with Administrator user.
If yes, please share the complete application logs, error logs, script logs and security logs of the timestamp of error occurred while logging into manufacturing apps console.
Himanshu
laue
(To:hchanana)
Hi Himanshu,
I double checked the password. In the security Log the error is only marked as warning. in all other logs nothing is listed with that timstamp. Furthermore, this Warning occured on two other machines.
As I said it is not only a problem with the FormLogin of Manufacturing Apps, but a problem with all FormLogins(even for Everyone).
Further info:
i have a postgres database installed
Laue
laue
(To:laue)
