KepServerEx Advanced Tag
zajaja
is there any limitation of number of Advanced Tags in KepServerEx ?
1 ACCEPTED SOLUTION
AndrewBlack
(To:zajaja)
There are no limitations on how many tags can be created within the Advanced Tags plugin.
Kind regards,
Andrew Black
AndrewBlack
(To:zajaja)
Kind regards,
Andrew Black
slangley
23-Emerald II
(To:zajaja)
Hi @ zajaja.
If you feel your question has been answered, please mark the previous post as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
