Kepserver call Oracle procedure
tim
Hi all.
I have created MSSQL stored procedure and could successfully call it from ODBC driver with parameters.
How can I do the same with Oracle function or procedure?
Thanks.
slangley
(To:tim)
Hi @tim.
Take a look at this manual to see if it helps.  If not, you'll need to provide additional information.  What version of the product are you running?  Are you getting any errors?
--Sharon
slangley
(To:slangley)
Hi @tim.
If the previous response allowed you to solve your problem, please mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
