With the trends in IOT and the use of it moving up the hierarchy would it make sense to make KepServerEX a bit more Enterprise capable?
Things like:
- Able to manage and run multiple projects - so different teams or lines/areas can be connected and changes can be limited to multiple smaller projects rather than just one
- Active Directory integration for configuration (and run-time if possible for UA?) security
- Web client access for configuration and control - Maybe through REST-ful API in ThingWorx? so users don't need to be given access to the server to make changes or manage
Luke,
Your suggestions are right on point with where the product is heading. I can't make any guarantees on timing however, on the backlog are a number of features similar to what you allude to in order to make KEPServerEX and ThingWorx Industrial Connectivity more accessible and manageable both through the ThingWorx interface, and through modern IT/IIOT infrastructures.
Kepware Product Management
